Will it fit?
HemiPar
Kentucky
Well here is my question. Will the disc brakes from a 80 Volary fit on a 71 Swinger? I have the Swinger and it has disc brakes with 4" bolt pattern. The Volary has disc with 4.5" bolt pattern. Does anyone know or have tried this swap? Thanks
Jeff
You will need all thedisc hardware and the spindals aswell as a pair of 73-76 Abody upper control arms and lower ball joints. The F-M-J body spindlas are about 3/8" taller then A body spindals and some say it cause problems with the ball joint over extending while others say it improves geometery. I have a set I plan on using.
Thanks for the reply AdamR. I hope your project comes together soon.
