will LA block huggers fit a magnum?
maca
australia
Hey all
I can only get LA block huggers here in Aussie. Will LA block huggers fit a magnum or do they have different shaped exhaust ports and will leak?
I have magnum headers on my la block that I just took the huggers off of. I would image it would go the other way also
Oh I forgot there is a little bit of the head that might have to be ground down
And maybe the truck mount pads on the block.
I am running LA small block headers on a Magnum without any issue's.
your rpm at 60 mph would be no more than a fast idle it would get great mpg .
Well, there is no 60's in AZ as all the main hiways are 75 but that means everyone does 80+
I get right at 25mpg at 80mph at 2,100rpm with a 400hp 5.9 Magnum.
Heck at 60 I'm just going into OD. :D
