will the CRAGARS fit!?!?!?!?
Wilnutt
ok dad decided he wanted to keep them 14's bc he wouldn't have to buy new tires... gotta know..right now got the 14x 5.5 ralleyes..upgradin' if possible to...i'm sure the fronts will work..but what about the back..i've upgraded from the demon's 7 1/4 to a b-body 8 3/4 (from a 66-polara), so keep this in mind..doesn't that mean the rears around 1.2" longer on each side???
PLEASE HELP!! gettin' down to the niddy griddy and need some BBP rims....
14x6 cragar ss
offset: -3
backspacing: 3.375 in
14x7 cragr ss
offset: 3
backspacing: 4.125
I think they will fit and look good. If you were talking 8" I might be worried
Not sure how much extra wide the B body rear end is. I going on your assumption that its about 1.2" wider on each side
I'm thinking the ralley has a 4" back spacing so the 7" crager should only stick out 1.5" more than the ralley. Someone correct me if I'm wrong.
Do you have a couple inches that you can go outside
i'm gonna have to check...it's exam week so..picked a rough week for this problem to be solved
i hope so..can't wait to get this plum crazy beast one the road..just need to get it all together...and need some rims that'll fit
