Will these work on 73 duster?
Ronnie Harris
Active Member
Cumberland
Have 73 duster , has been mini tubbed and 3 inch spring relocation. Can i run 15x10s w 4.5 backspace on 315 60 15s ????
They will physically fit in the hole, but in order to know if the backspace is anywhere near correct you need to tell us which rear axle you have. 8 3/4? BBP or SBP? What brakes? Is the axle stock width or?
Axle stock with, 8.75 rear,all drum brakes
I have 15x10 with 6.5 backspace and 30 13.50’s.Had to open the quarter panel up a bit in front of rear wheel.Might work with a radial as you won’t have to worry as much about the tire growing
