HotRod777
Active Member
66 Dart. Currently I have a slant with a later model over-drive bell housing (5.125 register) and 833 that is running/ driving fine.
I’m considering eventually swapping in a small-block. I have 2 specific questions:
1) If I use the later model small block over-drive bell (casting # 3743859) with a 130 tooth, 10.5” fly, will it physically fit in my firewall/tunnel? (I know the 63-66’s are tighter then 67-up, just want to make sure I’m not in for a big disappointment)
2) I have a set of the 64-65 273 exhaust manifolds that I would use. The drivers side is the long one that pinches down and then turns the outlet to point straight back like a header. Does anyone know if the larger 10.5” bell housing interferes with that exhaust?
Also, I know I will likely have to fab/ alter the Z-bar, that’s not a problem. The possible clearance issues with the tunnel and exhaust is what I’m worried about.
Thanks for any & all insight!
