Will this gauge work with my dart
The stock speedo is also mechanical so I don't see why it would not work. You will most likely need a different gear drive in the trans so the speedo works right and mabby a speedo cable.
it needs a threaded speedometer cable, mopars are clip on, at least mine was....
On my 65 wagon's custom dash I'm using VDO gauges and a matching face Porsche 160 MPH mechanical speedo. I had a custom speedo cable built that threads into the Porsche speedometer and the other end into the speedometer pinion in the 904. I'm sure I will have to play with the speedo gears to get the Porsche speedo to read the correct MPH/mileage. Still a ways down the road.
