wilwood caliper ?
tensec340
The LEGEND
Long Beach,L.I., NY
On my caliper's there are 4 bleed screws, one on each corner.
When you bleed the system which one or one's do you loosen to bleed?
Tried the wilwood site ,but still waiting for them to answer..................
Tim
i would assume the ones pointing up. I wouldnt think you could get all the air out opening the ones on the bottom.
I would think Wilwood designed these so they could be mounted forward of the wheel or behind. Thus a bleeder screw for either application.
Bleed from the top.
I think top one outside first, inside second?
Good question. The old K/H set up had one bleeder one it.
you actually want to bleed the inside one first as to get air out of the line coming in and that side of the caliper then the outside to bleed the second half. lot of top end cars especially Ferraris have an inside and outside bleed screw.
Tim, Do what 71dustar said. That is how I bleed mine also. Jeff
There ya go, the been there done that has spoken and now your in like flint!
Stop by when your done..... OH, when the Pinks deal?
