Windage Tray 4 bolt main
DRDIESEL
PapaClutch
Depew NY
anyone have experience with a windage tray on a 340 small block 4 bolt main stroker?
they build them in the pan now
I don’t have any experience with a factory windage tray and 4 bolt mains, but I guess it would depend on which oil pan you are using. There is not a lot of clearance between the main caps, and stock type oil pan. I would think if you bent the windage tray around the outside of the 4 bolt mains, it would hit the oil pan. I wondered the same thing, I bought a short block that has the Milidon 4 bolt caps installed, but I got it without the oil pan. It is at the machine shop now, when I dropped it off, was told that they were 3 weeks behind. That was 10 weeks ago
