Window adjustment question
Reddartowner
UCF Alumni....Go Knights!
Merritt Island, Florida
I'm trying to get the driver's window adjusted on my '68 Dart GT and I have a question.... What does the front division channel adjusting rod adjust..?? I can't figure what I need to do with it.
TIA,
Mark.
There is an adjustment that tips the top of the wing door and the window runner in and out. All I can think is that it is used to snug the top of the window to the gaskets at the tiop. It is a bolt with a slotted head and a locking nut. Is that what you are asking?
Yeah, its the one that comes out the underside of the door under the vent window. I figured it helps align the front channel somehow, but I wasn't sure if it moved the channel in/out or for making the window parallel to the door opening................
