Window hard to open/close
loganscuda
This/These
san antonio
67 fastback passenger window is really hard to roll up or down. Everything is greased and I noticed that some of the plastic strip in the track has come apart. I think it may be binding on the plastic strip. Have not taken apart. Where can I get that plastic guide strip that runs down the channel or how to fix. Thanks, Jason
Am re-doing my glass right now- I think this what you want- Year One #FD32230P. There are actually three small pins inside that plastic "slider" that follow a groove in the "A" post. Replacing it is a pain in the you know what.
Just a thought before you take it apart. Disconnect/ remove the crank mechanism so that it cranks independent of the glass. This should tell you if the binding is in the crank or the front/ rear glass guides.
