Window Regulator Application
dodgedart1968
Amston, CT
I need a window regulator for the driver side front door of my '68 Dart four-door. I posted a parts wanted thread.
Two questions to help in my search:
1. What model year regulators will fit a '68.
2. Are regulators the same for two-door and four-door, and front/rear. I suspect they're the same because the bottom-stop bumper has four positions in the regulator frame. (See the lower image).
Go online and download the 68 Chrysler parts book. Then locate the window regulator section and start comparing part numbers.
  1. Left to right would be different number
  2. Front to back would be different
  3. 2 door vs 4 door, don't know, but I suspect they would be different as well. (Longer glass)
  4. They may share parts of the assy with each other
Good luck
Good luck
Wow, huge document. I'm looking forward to diving into it.
Thanks for the suggestion.
Very hard to use the catalog because of its large size. Navigating 1641 pages in PDF format is difficult.
I've found that all Darts, Valiants and Barracudas use the same front regulator. Left/right are not common and the rear regulator is different.
Fronts I believe are the same 2 door to 4 door. I have cheap extra regulators from 67-9 cudas(same as yours), but shipping may kill it. Lemme know if interested.
Do you still have the regulators?. I’m looking for one for passenger side 67 Barracuda fastback.
