I don't recall if the cudas had the same odd rotating 1/4 glass as the hardtop valiant. If they pivot at the front edge and rotate down then I would use lithium grease. When I did mine years ago I cleaned everything real clean and applied a thin coat of spray lithium to all the rubbing pieces, moved window and reapplied. They still work fine.
