Windsheild trim removal
The removal tool is key and plan on ruining a few of the clips. You can get those in clip kits from Jims.
Here is the tool that I have used with ease. It's also a good idea to have one of those blue popsicle wedges.
Here are a few posts found doing a quick search.
http://www.forabodiesonly.com/mopar/showthread.php?t=27266
http://www.forabodiesonly.com/mopar/showthread.php?t=91859
To add to what drjayo posted...... Start at one end and work to the other end until the piece is all of the way off. Do not work from both ends inward. You will bow it. The plastic popscicle stick worked best for us. Don't be afraid to use a slight amount of leverage/pressure to get it between the roof rim and the trim. Oh, and you will bend the underneath lip of the trim some. Not to worry. It straightens easily and no one will know.
