trickiedickie
New Member
iF YOUR WIPER PIVOTS ARE LEAKING AND YOU HAVN'T GOT THE 15.00 FOR A KIT OR THE TIME TO DISASSEMBLE THE PIVOTS, TAKE SOME INNER TUBE RUBBER, CUT A 1 INCH CIRCLE OUT OF IT. USE A PAPER PUNCH TO PUNCH A HOLE IN THE MIDDLE OF IT, AND ALONG WITH SOME GREASE, PUT IT OVER THE WIPER POST AND TUCK THE EDGES UNDER THE SHEET METAL. iT WORKS WELL AND STOPS THOSE LEAKS RIGHT NOW!!!!!
