Never seen a poly-motor in a motorhome. It's callled a 318-3 (if I remember correctly) It was a industrial use engine. Used extensively for pumps, and forklifts, generators and such. There's a guy that races occasionally here in the Phoenix Metro area that has an old race car hauler, the kind that's enclosed where you drive the car up on an angle in the back. He has a 318-3 in it. (he doesn't go very fast up hills!) I started working in the RV industry in the late 70's and saw a few of those Winnie's come in with the 318's. They were always 318-3's The larger (longer) Winnegago's had 413's in them. The late 70 thru 1980 coaches used 440-3 motor's as well and had different cylinder heads. Again if I remember correctly the heads on the dash-3 motors had big plugs and different shapes because of a an additional cooling jacket around the plugs by the combustion chamber. Normal passenger car and light truck engines were considered to be dash one engines (ie: 318-1, 413-1, 440-1) The class A motorhomes used the dash three engines with the different heads. (ie: 318-3, 413-3, 440-3). See if you can see the side of the block It should say 318-1 or 318-3.
