Hello
I am in search of a wiper motor for my 1966 Dart. I believe the motor is fried. I sent it off to a shop and was told it was good to go.It appeared that the motor was never disassembled. When i re-installed it had the same symptoms. The wiper arms would move a little and stop. With the linkage disconnected from the motor it would run for a bit. The wiper arms move easily without the motor attached so I do not believe it is binding. I tried running the motor on the bench and it will not run at all now. It has a Prestolite motor with ERQ=4006 on the motor. I believe the part number is 2525269 and a 64-66 A body will fit. There are 2 connectors coming out of the motor. 1 has a black wire and a blue wire and the second connector has a Red wire and a yellow wire. I am new to the Mopar world and finding out some of these parts are hard to find. Any help is appreciated.
