kocuda
Ok all you wiring geniusis, and I know your out there, I've seen your posts with wiring diagrams and all, HELP!
My MSD 6AL took a dump and I'm installing a 6AL2. I want the lower rev stage to work with my line lock for converter loading, you know tie it into the line lock switch. But I dont want it to work for burn outs because the rmp would be to low.
Do I need to wire, in line to the box, another switch to deactivate the low rev when using the line lock for burn outs, and activate it for staging?
I'm installing the unit this week end and sure dont want to screw it up.
Suggestions?
Suggestions?
