wiring a tach.
rabius75
Dallas, GA
so, the green wire goes to the ( - ) terminal on the coil? black is ground, white is for the light and red is to the ignition switch? is this correct?
i found a tach in my room that i had from a long time ago. a resisitor in it was torched, so i replaced it. now i want to find out if it works. i took it from an old fury in the junkyard a while back.
