D danmc77 Well-Known Member Joined Sep 28, 2005 Messages 1,111 Reaction score 7 Location Barto, PA May 25, 2010 #1 What does a 340 block typically sell for? Specifically, a bare, standard bore block w/ no caps.
stroked 340 Banned Joined Oct 10, 2008 Messages 3,117 Reaction score 23 May 25, 2010 #2 I sold one last year,but it did have the caps.i got $450.00 for it..
C crackedback FABO Gold Member FABO Gold Member Joined Aug 7, 2005 Messages 19,187 Reaction score 5,980 Location 92201 May 25, 2010 #3 No caps means line bore = $$$$ Around $300-350 here for one done right. I wouldn't give more than $100 for it. I've seen Std bore blocks with caps sell for 275-450. I have a set of caps off a 318... if you need them.
D danmc77 Well-Known Member Joined Sep 28, 2005 Messages 1,111 Reaction score 7 Location Barto, PA May 25, 2010 #4 crackedback said: No caps means line bore = $$$$ Around $300-350 here for one done right. I wouldn't give more than $100 for it. I've seen Std bore blocks with caps sell for 275-450. I have a set of caps off a 318... if you need them. Click to expand... Thanks Rob - I have a set of 318 ones too. Sorry I haven't called you back - i got your message. Just waiting for payday to determine what I can afford first:-D
C crackedback FABO Gold Member FABO Gold Member Joined Aug 7, 2005 Messages 19,187 Reaction score 5,980 Location 92201 May 25, 2010 #5 No problem, you're good with me. If you can score the block for a benjy, then I'd do it. Point out the line bore issue and related cost to a block with caps..
