draginmopars
All rears from moser
all were 8 3/4 truck rears
10" wheels with 5" off set fit perfect in a Dart Swinger (Mini tub required)
2 are
53" wheel flange to wheel flange
re-spline axles
new green bearings
new wheel studs
new ends
new perches are install for springs moved into the frame rails
1 still in the boxes
1 installed, for set-up , 0 miles, never completely bolted the gear housing in or added fluid
then changed to a Dana
other rear is 45" flange- flange
new ends
4 link and ends are NOT welded yet, so you can change to any bracket you need
was set up for 24" between brackets
re spline axles with NO bearings
has long wheel studs
went with a Mo875 housing instead
Thanks for reading
Whats a fair price for each?
Thanks.:burnout:
2 are
re-spline axles
new green bearings
new wheel studs
new ends
new ends
Thanks for reading
Thanks.:burnout:
