magnumdust
I posted awhile back about a high speed vibration after having my driveshaft drop on the highway.(broke loose @ the rear end straps, a problem caused by me)
i had the driveshaft re-tubed and balanced and it still had a vibration. And i figured it would be something in the transmission and i'd need to replace it.
However, looking at the yoke today i discovered that one side of what the u-joint slides in doesnt have a tight pressed fit. You can spin the u-joint cap. Would that cause a vibration issue?
