[Found!] wtb a body backing plates
I have a set from a 8 1/4 rear blasted and epoxy painted 60 shipped?
Sorry, but no you don't. 10x 1-3/4" rear brakes are SBP, and 8.25's didn't come with the SBP. So you either have SBP brakes from something other than an 8.25 or you've got BBP 10x2.5" brakes from an 8.25, and you can't interchange SBP and BBP backing plates. Offset on the backing plate is different.
are the backing plates and drums 41/2 bc ? are the brake set up 10x13/4 ? thanks
10x1-3/4" rear brakes will have the 5x4" pattern, not 5x4.5" unless they've been redrilled, and that's a whole different can of worms. What rear axle do you have and what is the bolt pattern on the axles? Have they been re-drilled?
Here's the rear I pulled from my dart. It has 10" brakes on it. If you I will pull the brake parts off for $50 plus pay pal fee (3%) and shipping from 78065. They were working brakes yesterday, but I would assume they need gone through.
It's already been asked here before but it's CRITICAL: Do you have small bolt pattern axles (4 inch) or LARGE bolt pattern axles (4 1/2 inch)? The backing plate offset is different. Small bolt pattern backing plates will not work if you have converted to large bolt pattern axles. I have a set of the loaded 10 inch LARGE bolt pattern backing plates, drums & hardware for $100 plus the ride.
