70wayfarer
well I never anticipated this happening. got a moroso deep pan oil pickup from mancini. had set it up before engine went for machining so I could modify my pan. at this point all was good.
this is a 360/410 stroker. :burnout:
have now assembled the short block and went to fit the oil pump with the pickup screwed. all is still good until I gave the crank a turn and the f!#^ing rod bolt hits the boss on the end.:banghead:
I was going to get the miloden one but oh well. not sure if I should clearance the boss with the die grinder or get another pickup. only thing is if I clearance it will it brake sometime in the future.
any advice here please.
