[FOR SALE] WTS Complete Rear Mount Turbo Kit (RB/BBM)
Sweet5ltr
Jacksonville, FL.
Rating - 0%
0   0   0
Engine is getting replaced by a 470-500ci (400 low-deck) stroker or 493 RB, unfortunately, time to let this go to purchase the stroker kit.
Need this gone, stroker is getting built next week. Last combination offer.
Basis for a 700-1,000HP Turbo Build:
Turbo + Filter + Downpipe ($900+)
EV Bonnet ($260)
Complete A2W Intercooler setup ($600)
Carb ($1,000)
$1,750 shipped
Extreme Velocity Pro 4150 Carb Hat (+ Spectre for low-hood clearance)
CSU 750 Blow Through Carb
440 Valve Covers w/ oil return fitting
440 (factory electronic) Locked Distributor
Borg Warner S475 T6 1.10ar Turbo
Lunati Custom Solid Lifter Turbo Camshaft & Lifters - Nitrided - .526/.546 - 235/243* - 115 LSA
Aeromotive BRFPR w/ AN fittings and Aeroquip hose
2x Walbro GL392 fuel pumps
Air-to-water intercooler, 5-gallon custom ice tank with rule2000 pump, and heat exchanger
K/N filter w/ clamp, V-clamps, Charge tube coupler w/ T-bolts, 5" down pipe
8, 10, 12 AN Aeroquip fuel line.
Hardline for oil return
Every imaginable AN fitting
MSD Boost Timing Master + MSD 6AL (I will include this, personally I would go MSD 6530)
AEM Uego Wideband + 02 Sensor
Dynotune Boost Gauge
2x autometer 2 1/16 cups
Turbo mesh heat shield
T6 Flange and tubing
Shurflo oil return pump
RPS 50mm BOV + stainless charge piping
Wyntonm 60mm wastegate + mechanical boost regulator
All required clamps, couplers, and hardware from RacePartsSolutions.com
Custom 2.5" hotside-3" coldside tubing, most of the hotside is wrapped and painted. (-$250 if you don't need it)
$2,750 + shipping/free pickup
EV Bonnet ($260)
Carb ($1,000)
$1,750 shipped.
