Yay,...It's Paid For,...(part 2)...
jaimus
Old School ASE Gold
Hadlyme, CT, USA
Pam bought this Poncho in 06 before we met,...so far Its been a pretty good car, rides nice,..We use it for road trips and Its her daily driver,...Put some Michelins on it, Brakes x4, Rotors,...all the usual maintainance stuff and one 450 dollar emissions part,....Has everything cept sunroof and Nav,...Was waaaay behind on the payments when we met,had some deferred...Got her straightened out, paid it off earlier than expected,...
Took her truck shopping last week,...She wanted a Silverado till we looked at the Ram 1500,...I believe We'll have a Ram in the driveway by years end,...What Momma wants,...Momma gets...
Thanks for the info,...Probly be the hemi, The V6 comes with the new 8 speed which I wouldn't trust just cause Its too new,...She is looking at the 2013 Express or SLT crew cab/short bed, (in my opinion is a womens truck), It won't be for workin anyway's,..Cheaper and more legroom than the comparably equipped Chevy,...Hopefully we'll get one at years end after the 14's come out, the prices are usually better,....
If you are buying new try and get. Friends and family discount voucher that might help also.
Good luck on the new truck hunt
My 2011 1500 Ram 4x4 with the 4.7 has been a great truck. What is wrong with the 4.7?
Dodge 4.7 Engine Problems
The Dodge 4.7-liter PowerTech V-8 engine has received mixed reviews from owners since its debut in 1999. Yet most of its quality issues center on lack of scheduled maintenance that will doom any engine to an early death. The 4.7-liter V-8 is more compact and delivers more power than its predecessor, the 5.2-liter engine.https://now.ehow.com/cars?utm_sourc...roblems&utm_content=intext1&utm_campaign=none
Background
  • The 4.7-liter aluminum engine was first introduced in the 1999 Jeep Grand Cherokee and then the Dodge Dakota pickup and Durango SUVs a year later. The Dodge Ram picked up the 4.7 in 2002. Horsepower ranges from 302 horsepower with 329 lb.-feet of torque in the Dakotas to 310 horsepower and 329 lb.-feet of torque for the larger Ram pickups, according to allpar.com
Maintenance Issues
  • Like all automakers, Chrysler LLC, the parent company of Dodge, adheres to a strict warranty policy. Engine failure, a recurring issue with Dodge Durangos and Dakotas, has centered on the lack of proper maintenance. Although an owner may provide evidence of regularly scheduled maintenance on the vehicle, evidence of oil sludge, metal shavings or failure to replace parts at scheduled intervals could void the warranty.
Engine Failure
  • Engine failure can occur after 70,000 miles due to poor or lack of maintenance. But engine failure also has been known to be caused in some 4.7-liter engines with abnormally thin engine block walls on some engines. The thin walls cause excessive heat, which over time will cause oil to become gummy and the heads to crack. Only strictly following the factory recommended maintenance schedule can minimize the exposure to engine failure and ensure the warranty will be honored.
Exceptions
  • Although engine failure in the Dodge 4.7-liter V-8s haven't reached significant proportions, carcomplaints.com reports that owners have complained of sudden loss of oil pressure with as little as 36,000 miles on the engine. Internal examination of the engine has found oil sludge to be present, although diagnostic checks fail to pinpoint the source of the failure.
Oil Sludge
  • Oil sludge appears to be a common problem with the 4.7 engine. It has been known to build up in no matter what the weight of the motor oil. Oil sludge is usually due to a faulty positive crankcase ventilation, or PCV, valve. Changing the PCV and switching to high-mileage oil will probably solve the problem, according to bobistheoilguy.com.
Overheating
  • The 4.7-liter with more than 70,000 miles is in danger of cracking a head if the driver continues to drive it when the engine is running at 235 degrees on flat surfaces and up to 250 degrees on hills or towing a trailer. A diagnostic of the radiator, thermostat, water pump and gauge should pinpoint the problem.
Oil Foam
  • Oil foam, usually evident on the oil dipstick or inside the oil cap, also is a result of a faulty PCV valve. A properly working PCV valve vents out excess condensation that builds up. The 4.7-liter V-8s prone to oil foam may require a 3,000-mile oil change instead of the 6,000-mile changes recommended in new models.
