Hey all Trying to clean up the garage and generate a little cash for a few items needed to put the finishing touches on My Dart I have several threads going already for some of the larger or more valuble items but I thought I would just lump all the little stuff here in one thread . most of these prices are just asking so if theres anything that appeals to you send me a PM with a reasonable offer! Thanks Fabo !!!
1 carter M60514 stock volume fuel pump 318/360 bought new back in Feb. It was used to get a car mobile then replaced with a high volume unit when the engine was swapped out) $20 shipped
1 water pump appears to be a high volume unit cast impeller . $25 + shipping
(Water pump is sold)
14" air filter base with 5" carb bore $5
14" X 2" air filter never used $10
bisquit style locking motor mounts Tall maybe for a truck ? $5
A body upper rear shock studs good cond $10
A body front spring hangers drilled with larger 5/8" bolts $20
Mopar performance manual brake adjustable push rod end was cut / shortened ground maybe repairable $10
73 dart Dome lamp housing clean no corosion has harness/plug no lens $5
All parts located in SF bay area N Cal.
As always thank you FABO !
