"You could be running way too much power if"
67Dart273
Idaho
Several years ago I was into a bunch of amateur operators, and I guess what started this was when Jeff Foxsworthy came up with his "you might be a redneck" jokes
Ours was "You could be running way too much power."
IE............. "If you key up your handheld and the antenna gets warm..........."
..................."If you key up your handheld and the antenna gets RED............"
and etc.............. when I came across this C/L ad tonight, LOL
http://spokane.craigslist.org/tls/4132400524.html
30 KW Load Bank - $1000 (rathdrum)
I have a military grade 30 KW Cannon load bank, model L-63, that will test anything from 1KW up to 30KW and has only been used 3 times has pelican case (Hard Case) with wheels, Also comes with original owners manual. call or text for more info or pictures 208 four four *** XXXX
I've never seen one of these in use. Do you use it in conjunction with an oscilloscope, to test how a generator or inverter is behaving under load?
Yup. Years ago I repaired a 2KW inverter for a guy and had no "handy" way to try it out, so we used to sell 1KW mogul base lamp bulbs IE gyms, and warehouse lighting, etc. I wired up two of them. Our shop guy sees this and was absolutely dumbfounded. "Howya lightin' them big bulbs with a 12 V battery??"
THATs IT!!
Called my friend in Spokane sometime ago, we are both amateurs
"You on the air?"
"Uh...........yeh..........how'd you know?"
"The water level in my toilet bowl keeps going up and down"
"So, you're sayin' I'm..................."
"YUP ........YOU are running WAY too much power!!"
