1969 Dodge Dart GTS
Awesome Rob! Now the fun begins and you'll actually see some progress. Good Luck, man. I'm all the way over on the east coast, but I have been where you are now and I have been following your build for a long time and if I can help, just drop me a line. Check my thread out and maybe some of my mistakes will save you some heart ache.
69 Dart GT Conv. 340-6pak
Martin
Martin
Thanks Martin. I have followed your build too. It is awesome.
Good to see the car out of the paint penitentiary.
What do you think the time frame is to get up and running?
Looks great! Enjoyed reading through the build posts. I had a 69 GTS 340 4 speed, white/black top and stripe back in the mid 80's in HS. Look forward to seeing yours go back together.
Heater is in. Headliner is in. Gas Tank and sending unit is in. Hoschkiss shocks are in. Sound deadener is mostly in, did the doors and the roof just have to finish the floors. Body plugs are in. Started to go through the wiring harness and have to make some repairs. Side glass is in thanks Belmateo.
Some stuff done today. Wipers, brake master cylinder, washer, pedals, rear bumper and taillight housings. Lots more to do.
Does anyone know what is correct from the front of the radiator support behind the grill, black or body color?
It should be a semi flat black. Shot at an upwards angle (guy was in a pit), stops at core support. There should be some good M code GTS restorations out there to copy their pattern.
definitely flat blacked out. Dodge did not want to see the color behind the grille. no real pattern,
just sprayed until the color was gone.
