Yah, I do suspect the tach...or the one on my dialback light, one or the other. timing light reads 100 rpm higher than the tach.
No, it's not that loud. there are times after a long drive to or from work...54 miles each way, when it will be a bit louder...fully warmed up I suppose. Today's video was after a run for football beer.
I am running Royal Purple 10W40 synthetic. It was quieter with Castrol GTX 20/50.
It's all gonna get better anyway soon with the hughes roller rockers...for the price, they'd better not be crap...damnit!!!!
I wasn't going to say anything but I thought about it and this is a wide spread issue so I'm going to speak what I know and let the peanut gallery do its dedicated work.
If I were using hydraulic lifters, I would never ever run an oil lighter than 50. It could be a 15w50, or a 5w50 but always a 50.
In 2003-2004 around there, there was some street car classes that mandated hydraulic roller lifters. We were doing some dyno testing on one of these things, which are a PITA anyways. We did some upgrades and updates and on the dyno we were down 15-20 HP and about 600 RPM lower.
After we spent an hour trying the blatantly obvious, we pulled the notes from the earlier tests.
The only difference was the owner just had to switch out to a 30 grade oil. We put it back to a cheap 50 and got a 30 HO gain and picked up 750 RPM. The lifters HATED thin oil and would go into some sort of hysterisis or something. I cringe when guys have to put a 20 or even a 30 grade oil in an engine with hydraulic lifters. It just causes issues.
New, before all the nattering nabobs come along and they'll me their Honda uses a 20 and hydraulic lifter, it's NOT THE SAME. The ramps on some of these cams are fairly fast, and they take a bunch of spring pressure and a thicker oil.
Lots of guys with valve train issues like the OP could possibly eliminate some of their issues with valve springs and a heavier grade oil. If you have a newer designed lobe, 100 on the seat won't cut it. If it's a HRT, 140 is the low side for spring pressure.
