downsr
Looking for a carb for a slant six. Linkage is the rod type.It has a offenhoser with 600 holley on it now trying to find adaptor plate from 4 barrel to 1 or 2 barrel carb with rod type linkage
600 Holley what? Vacuum secondary, Double pumper? A 4160 based VS model should't over carburete if tuned properly, You've got a 290cfm 2bbl already, even if theThe car is a 1965 barracuda. The engine is a 73 do not know what it is out of. It has Clifford headers with offenhouser intake with 600 holley.The engine has nothing else done to it as far as know. It has rod linkage
Hey, You, SCAT!!! Get outta here You !!! Dagnabbit, Whippersnappin' V-8 Pimpin',............!!!!!I would start with a Holley 750.
Under that I would put an Air-Gap.
And then under that, I would put a 408.
