Sounds l like a sexual problem.Always a Can-O-Worms!!!! Probably will be a combination of two things. A little more trim, and move the centering hole a little as stated above^^^.
Maybe she was a heI had a Lady Psychologist tell me in a training once...she was the trainer....That all men have a feminine side but are afraid to admit it. Of course I couldn't keep my big mouth shut and I said...well that may be but I can tell you this my Feminine side is a lesbian because I love women...the whole room erupted in laughter.....She tried to have me thrown out ...I think she was a Lesbian and was afraid I might sick my Feminine side on her and having sex with another woman that looked like me kind of shocked her. She was attractive too.
Did you?Bump
The proportioning valve is probably installed backwards too and that's why they work.Still have the dumb "Brakes connected backwards" problem BUT brakes work good...
I hope it is for everyone, me, not starting out well at all... seems I am all alone at times even when I have folks around me.
The deer will all be bedded down someplace dry and out of the wind anyway.Well the hunting decision has been made, I ain't going. Forecast changed to severe thunder storms from dawn till dusk, 30 - 35 mph substained winds and gusts up to 60 mph possible. Ain't sitting in no tree stand for that one
I get that way too. Sometimes when you are already going, it's best to push a little further to make the next day's work a little easier.I.cant.stop....
Once i got broken bolts out, cleaned surfaces and trued manifolds 50%
(They are only half bad now)
I wanted to get them in place and a couple bolts started. That much less to do tomorrow. So much for a weekend off....
Probably be more productive than hanging on to a tree rocking in high winds!Tempted to get up early anyway and work on the dart
It is me so probably notProbably be more productive than hanging on to a tree rocking in high winds!
Man *****!I've been telling people for years I'm a black women trapped in a white mans body.
Got the problem fixed on my 69. A flapper wheel on my grinder, got some more lip clearance, and reamed out the centering pin/bolt/ AND an hydraulic jack to push back that ridge inside the inner fender....
All good now. Cost=Nothing!!! For everything else, there is Mastercard!
The Prop. valve is on the rear line.The proportioning valve is probably installed backwards too and that's why they work.
