rmchrgr
Skate And Destroy
Thanks Rob. I give myself a B-.
I don't know about cake Denny! Let's just say I got through it. Took your advice and started at the center top which seemed to work OK. The most frustrating part was where the two sides meet in the middle. The joint is not a show car job. I just hope it does not start to separate or anything. Guess we'll see in a few years.
One thing I'd like to point out is working with the weatherstrip adhesive sucks. At first, I followed the directions on the package and tried to get the material on both the metal and rubber but that turned out to be too difficult because it tacks up really fast and wont spread. If you try to spread the glue in the opposite direction it will pull off. It also tends to drip which creates long, wispy strands that invariably wind up where you don't want it. You basically have one chance to kind of paint it on. I found the best way to get it on consistently was to use a cheap 1/2" detail paint brush. Still made a mess but I was able to contain it a little better.
Here's the first side done.
Complete.
Tools of the trade. After the first half, I cut the bottom of the brush bristles because it hardened up.
Not sure how I'm going to get this excess residue off, probably Goo Gone on a Q-Tip or something like that.
More to come.
nice job, im following along....Rich
thanks for the progress report. Always nice to see how it goes on the glory trail.![]()
From another Rob, we're all our own worst critics. I think it's comin along great.Thanks Rob. I give myself a B-.
Thats the truth. When “WE” are working on our cars and trying to produce a nice end result, we are tough on ourselves. It’s the inner drive. To drive ourselves as hard and far into that area that may never be happy with the end result. But that is also what makes and brakes a car never mind the slap stick guys (like myself from project to project) that just assemble stuff and call it good enough. That has a time and place per-project. That’s fine for a certain someone or project. Obviously not for Greg.From another Rob, we're all our own worst critics. I think it's comin along great.
Stay tuned for more hack work.
I will suggest that the OP use ventilation, a one-piece paint suit, Long sleeve t-shirt under the suit, a head sock and a full face respirator, rather than absorbing all the chemicals in the paint via skin and eyes with a 1/2 respirator and bare skin and kerosene for clean-up. A cool shower after painting is also a good idea as even with all the gear there is still some exposure. When sanding catalyzed paint/primer; ventilation, a welding respirator, long sleeves and gloves should be used - those sanding particles are toxic - the chemicals attack the central nerve system. Take a cool shower when finished.
From some one who has been painting cars a long time
