I think the people that say that have no clue, and sound like gm people..
Major surgery would be you taking the seats and interior out cutting the floor and old trans tunnel out....
When in reality you are dropping the trans mount lower in the trans cross member and shaving the body cross member..
EITHER way... just think about exactly what needs to be done for ANY gm trans to work...
Flex plate, bell housing or adapter, making SURE it is in line (or just gonna throw it in there)... linkage, kick down, vacuum, cooler lines... driveshaft....
Sounds insane now doesn't it...
The easier way out is usually the insane way...
Might as well drop in a ls with the trans.......
If you go that far might as well just get a camaro....
