Thanks Tony, but my car doesn't take the bulb you have pictured and thanks Mike but it doesn't take a 211. I would like to think what's in my car is original, I've owned it since 1988. Just to recap, its a 1968 Plymouth Barracuda Notchback, I'm working with the dome light mounted on the ceiling about my head. It will require a bulb with the two contacts on the same end, not opposite ends like a 211. My dome light takes something more along the lines of a 1134 bulb without the large head but more enlongated. I can't see any indication that the setup in my car is not original, there has to be someone else with a notchback using the same dome light. Lesson of the day, don't misplace stuff you remove from your car, not even a bulb.
