Hi guys,I have a set of ( # 1600) Hughes banana grove rocker shafts that I'm planning to use in a 360 with a set of MP non adjustable stamped rocker arms.
I noticed that the (# 1600) Hughes shafts differ from the stock shafts mainly in the orientation of the oil holes: While the(#1600) Hughes shafts have the oil holes drilled to line up with the rocker shaft bolt holes, the stock shafts have the oil holes drilled 15 degrees offset compared to the rocker shafts bolt holes .From what I've leaned the reason for the offset holes is for better lubrication of the area of maximum contact/friction when properly installed !!!. with(#1600) Hughes shafts you only need to make sure that the oil holes are pointing down .As far as banana groves, they are designed to improve lubrication.
Has any of you guys used a combination like this? . Any reasons in favor or against doing it ? I'll 'appreciate your inputs.
Thanks in advance.
Thanks in advance.
