Valvebounce
I'm building a car on a very tight budget. The cam I'm going to use will require a hi-stall converter. Since my budget is tight, I'll either be using a cheap aftermarket one, or getting a local shop to make my existing converter into a Hi-stall unit. The engine is most likely going to get a 150 shot. I've read that big dollar performance converters have something called an "Anti balloon plate" for nitrous use. How much of that do you reckon a cheap (Like a boss hogg) or modified factory converter hack before it coughs it's lot?
