wanted B&M flexplate 10241
cuda67
Florida - Thonotosassa
I need the above flexplate 10241 to mate my 904 to a 360 magnum. They are no longer available through B&M. They still have 10239 but that is for 1971-1992, pre magnum 360. Any help would be great.
I looked for one for a while and finally gave up. You can run a weighted 360 magnum flexplate from a 96 up magnum 360 and knock the weights off the 904 converter or if you are running an aftermarket neutral balance converter it will also work with the weighted flex plate. I found one for 30 bucks.
Yeah, that sounds like the best and only solution. I spent the better part of today on the phone to California, B&M, Advance Adaptors, PRW, and no one has anything. Is that the flexplate that has to have one of the holes elongated? What did you do for pullies and brackets? Nothing on my 318 will fit. I also have to change the power steering pump, no place to attach the brackets from the 318 and the alternator doesn't quite work either. Man, I wish I knew what I am doing.
Thank you for the information and wish me luck>
