jhdeval
I know that most people recommend the FirmFeel anti sway bar for the early A bodies but I don't have 300+ for it. Does anyone else make a good bar that is not quite as expensive?
I had front and rear sway bars installed on my '74 Valiant when it was in the shop for other front end work. Otherwise, I would have done it myself as the instructions indicated it was not complicated. Looking at the final installation, it looks easy to install too.
All you will need is a drill for a few holes. I used Hellwig sway bars.
It is about 10% softer than a solid bar but it is plenty of spring rate for an early A-body.
It is a tubular bar and it weighs 11lb. This is about 1/2 the weight of a 1-1/4" solid bar. It is about 10% softer than a solid bar but it is plenty of spring rate for an early A-body. Here are some pictures of the bar and its mounting. I may be a little biased but these are the best in the industry. The brackets are made from laser cut and CNC formed 3/16" steel.
I'll believe ya on that! I've got an old 1" Hellwig bar on the front of my '69 Dart, and I couldn't even imagine wanting more stiffness than that!
Yeah, every single piece of that bolt together mount just looks like a stress failure waiting to happen. Lifting an apple with a toothpick comes to mind...
