(wanted) Viscous fan/clutch fan
swinger340
Maine
Have one but the shaft is to long. Looking for one w/ shorter shaft. The one i have will not fit w/o clutch hitting the radiator. Going in 340 A body.
What dimension do you need? I have one 5 blade, finned clutch - 3.5-3.75" good clean pull. $25 and the ride from 92780
hayden fan clutch 2765. bought one from sumit. its shorter than the mopar one I used it on my 340 67 barracuda works grate
Go with this one. It should work for you.
