Tools explained....
inkjunkie
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh--!'
SKIL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes , trapping the jack handle firmly under the bumper.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tension strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object you are trying to hit.
UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
SON-OF-A-***** TOOL: (A personal favorite!) Any handy tool that you grab and throw across the garage while yelling 'SON-OF-A-*****!' at the top of your lungs. It is also, most often, the next tool that you will need.
Hope you found this informative.
Lmao. I have an 8lb sledge with the handle cut off like a shop hammer. I call it my sorry bastard. ''You're gonna come loose one way or another you sorry bastard.............''
Great definitions and explanations. Brought back fond memories amid the laughter.
Back when I was an apprentice mechanic I learned that each mechanic was partial to a particular brand of tools such as Craftsman, Mac, or Proto. There was one brand that everyone swore by........... DAMN Tools. They made every tool imaginable as well as bolts, nuts, water pumps, carbs, and VWs.
So do I, only it's a 10 pounder with a stubby handle. I call it the He-Man Mini Sledge :D
Also have a homemade Hub/Bearing Puller... 1/2" Steel Plate with a 1" Steel Rod and a 50 pound Sledge Hammer Head.. It's a 2 person tool, one to slide the hammer, and the other to catch the puller & hub when it falls (so it doesn't swing back and break your knees)
Thanks I needed a laugh at this time of the morning
My dad and I both use a cheaper variety of tools call F**king cheap Sh*t.
Lol! I've had surprisingly good luck with the canadian tire brand tool. Mastercraft pro I think. It's made by proto in china,but is much more reasonable to purchase. What can I say..It's one China made thing I havent been able to break.
I have a claw hammer I cut the claw off to do body work but I found it to be my "GET IN ANYWHERE BEAT THE **** out of it hammer"
Lawnmower left out in the rain: a resistance device that builds the muscle tissue in the lower back, shoulder and pulling arm. Ideally used to condition body for impending sickle swinging work.
Torque wrench: Device used to measure the shearing point of bolts.
Adjustable wrench: device used to round off flats of fasteners.
Channel lock pliers: Tool used to pinch meaty part of palm adjacent to thumb. Works on any finger inside handles too.
Left hand threaded lug nut: Device used to time impact guns ability to shear wheel stud. Better guns use less time.
Adjustable wrench: Chinese professional socket set.
Round point shovel: Manual Backhoe that puts blisters on your hands and wears out you back.
Sharp shooter: Tool used to cut phone and cable lines. Also known as a poor man's trencher.
Buffing Tool: tool that makes sure you replace your windshield.
