demon seed
The Original Demon Seed
1971 Dodge Demon (originally a slant six Demon), car is completely rebuilt, nothing to fix just drive, asking $22,000 and located in southern Alberta. Recent (2 months ago) 3rd party appraisal for replacement value vehicle insurance at $30,650.
-1970 383 with pocket ported and polished heads and Crane springs and locks
- MP .509 lift / 292 duration hydraulic cam
- Hughes 1.5 roller rockers, banana groove shafts and holddown kit with Hughes custom length push rods
- Aluminum high flow water pump and high flow thermostat
- 9.5 to 1 compression
- Edelbrock RPM Performer intake
- Demon 750 double pumper with 1" 4 hole spacer
- Schmacher engine mounts, torque rod and chrome Tri-Y headers
- Milodon windage tray with high volume oil pump and high volume mechanical fuel pump.
- Rebuilt 3 core rad with B+M tranny cooler in front.
- New alternator
- 727 tranny with shift kit and aluminum deep oil pan and pickup extension.
- B+M Quicksilver ratchet shifter built into original auto console.
- TCS (no not TCI) 3000 stall converter.
- high torque mini starter
- 741 / 8 3/4" sure grip rear with green axle bearings and 3.91 gears
- Balanced drive shaft with new u joints.
- New 2 1/2" exhaust with H pipe and Dynomax Super Turbo Mufflers
- Sub Frame connecters
- All brake lines new with dot 5 fluid, with manual brakes with Kelsey Hayes discs on front and factory drums on back.
- Completely rebuilt front suspension and steering with power steering
- Interior has new rugs and front and rear seat covers, new dash pad with mechanical oil press. and mechanical engine temp. gauges
- AAR one piece hinged 6 pak fibreglass hood.
- New fuel tank and sender
- Cragar SS 4" BC 14x6 front and 15x7 rear wheels
- 225x70-14 front and 255x60-15 rear
Also comes with 2 15" ralleye and 3 14" ralleye wheels all with rings and hubs
- 2 bare stock 906 heads
- new in the box front rotors and 2 sets of rear brake shoes
- Complete spare ignition system, distributor to orange box with resistor and harness.
- Color matched stock flat hood
- 2 ET street radials with 2 runs on them
PM if interested and we'll exchange e-mails and/or phone#s
[ame="http://www.youtube.com/watch?v=3hmi6jCdhTs"]71 Dodge Demon - YouTube[/ame]
- New alternator
