340 and 4 speed junk for sale
kujo
NC
I've got a bunch of stuff I'm looking to sell.
73' 340 block been bored .030 has main caps from another 340 (will need line honed) also where motor mounts attach looks as if it had cracked and been repaired (poorly welded) asking $350
A body 833 4 speed was told it came from a 70 Duster asking $400
Hurst Super Shifter $125
833 trans case $75
340 steel crank turned 30/30 $75
833 b body tail housing $50
SB flywheel fresh resurface internal balance $115
Don't be shy. Make an offer. No reasonable offers refused. Everything must go!
i need that trans case if it is cast iron........... and would you do 70.00 shipped to a friend in n.c?
Whats the date code on the tranny case? p833 _ _ _ _ also the one for the 70 Duster?
Area code 20601 for the empty case. I'm extremely interested
Bump.
