WTB: V8 K member for my duster
jeremy2146
Castle Rock, WA
Rating - 0%
0   0   0
Looking for a small block V8 K member for my 76 Duster. I dont know whats going on but I'm thinking mine is a /6, cause the top of the drivers side mount it trimmed, there are washers on both sides and the drivers side just touches the engine block, and it has a 318 in it. Gonna run some numbers tonight and see if it was a /6 car. Really want to make this right!!! I had rigged up stuff!
A picture would help and which K frame are you looking for Biscuit or Spool mount (Spool mount is the better of the two).
So here are som pictures.....I found that it is an original /6 car and it is obvious now after some research, but you would think the adapter mounts they used would fit a little better.....just poor setup....definately going to put a V8 K member in it....is there anything else I will need to change it over....It looks like the steering will be fine...but this my first Mopar.
