1971 Dodge Demon For Sale $8500 or Mopar Trade
alleyoopmgv
Wisconsin
Location is near Hudson, Wisconsin
1971 Dodge Demon For Sale or Mopar Trade $8500!
For sale is a 1971 Dodge Demon Dragcar 10 second 1/4 mile 440 pump gas racecar.
The car is really consistent, I have time slips to prove it. Anyways here is some info on the Demon.
71 Dodge Demon Drag car . 10.56 Best 1/4, consistent mid 70's
1.50's 60' times
1/8 mile times are 6.80's
Strong .30 over 67 Steel Crank Pump Gas 440
8 point cage
Iron heads
Line lock
Fresh Racing 727
489 8 & 3/4 410 Spool Moser Axles
10.5-1 Ross Pistons
>525 Comp Cam with 1.6 Rockers
2 inch Super Comp Ceramic Headers
New Q-A1 Adjustable Shocks on all 4 corners
SFI Balancer and Flexplate,
Tranny Blanket
4500 Stall converter (Dynamic)
Auto Meter gauges, VDO memory tach w/ shift light
8 gal. fuel cell
MSD 6al-2, Two step with Rev Limiter
2 Optima Yellow Tops
Tilt Front end
Frame connectors
Driveshaft Safety loop
Bought new 5 point harness last spring, so the belts are good for another season.
Motor was freshened and gone through in the winter of 2009. And the car was run very limited in the 2010 and 2011 seasons.
This car is very solid, trunk extensions, floor boards, frame rails, all in great shape!
__________________________________________________ __________________________________________________ ____
Please, serious inquiries only, $8500.00 cash buys it, no checks of any kind will be accepted!
Trades ACCEPTED! No projects, open to all Mopar trades! In a perfect world, I'm looking for a low 12 second street/strip car, but willing to look at street cars also. Will trade even up or lower with your cash to boot.
1.50's 60' times
8 point cage
Iron heads
Line lock
Fresh Racing 727
10.5-1 Ross Pistons
Tranny Blanket
8 gal. fuel cell
Tilt Front end
Frame connectors
how about a 72 black duster your car and 6000 nice wing scoop centerlines and more
Don't let that price scare anybody, I need me a Duster again!!!!
Check out my 75 duster forsale. It's a small block
Car. Engine ran 11.92 in my old duster. This one ran 12.60's with a really tight
Convertor. Now I have the 4400 contertor back in it. Should run low 12's or high 11's again. Too bad u weren't closer.
pm sent to you
You should haul this to the Mopar show in Farmington this weekend, would your new truck pull it?
That was my plan A, but I would kind of like to sell the silver truck first. I do have another truck for pulling. It's a 92 3/4 ton, rust free!
I can't believe you still have this car! I still have the Duster you like. I've put a whopping 22 miles on it in 2012!
I'm seriously contemplating a possible trade with you. The thing holding me back before was that I'd never use the Demon. Turns out I never drive the Duster, so what's the difference if a Demon sits in my garage or a Duster?
I would do some trading on my 70 duster in my Avitar. It ran high 12's last year, but have since put W-2 heads on it and havent had a chance to get it back to the track after tuning it. It is a street car, no cage, pretty solid no rust anywhere underneith. 360, 727 3500 stall 8-3/4 with 4.56 gear. Comes with 2 sets of wheels and tires Convo pros and a set of ralley wheels.
Sounds good to me!
