its a shame it rotted out 340 part out sale
340plot
the bushy bush
va
Rating - 95.8%
23   1   0
here are some parts off this 73 340 numbers matching car, and even found the build sheet behind the seat!
it had disc brakes, but someone robbed most of the stuff off them. so, i have just the caliper mounts, and spindles. i would think that the spindle may still be usable if the threads are chased. hot bout 20.00 for the pair?________SOLD
here is the power disc brake master cylinder, booster and if you need the rod. 30.00 for the setup. 10 buck more, you get the proportionate valve----------SOLD
set of duster emblems. 5.00
here is a un cracked 73 grille, with bezels. i was told that there is a way to tell a 340 grill from a regular one?
this thing is really nice. 50.00
here is the driprail chrome. it has one tiny flaw, ( ding the size of a pencil tip. could not get it to show in pic) other wise would be show quality. how bout 45.00
here is front windsheild trim nice shape. 40.00
here is rear back glass trim. also real nice 4o.00
back bumper. does have a little bend spot, but if sold, ill pull it off car, and i know that it will straighten right out. ill do it before it is sold 40.00
it is in driver condition
blue fiber board headliner. in driver shape. no holes. may need to be repainted. 50.00 no shipping
here is quarter glass both in nice shape. how bout 30.00 for both. i would give them away, but just so darn hard to get out
set of 340 spool mounts. rusty from sitting on floorboard, but i think a blasting will cure them. 40 for the pair
all prices do not include shipping.
all parts located 30 minutes from martinsville international speedway in va
more pics
How much for those clips that hold the shoulder belts against the headliner?
the car also have a super clean and rust free roof/////////////// ill get it off, 75.00 you cut off, 50.00
is the motor or trans going to be for sale ?
Does it still have the antenna assy? I mainly in need of the "U" shaped base that holds the antenna to the underside of the fender.
lol that's what i needed....for about 3 years just ended u buying the whole freaking assembly lol good luck to ya!
Did you sell the disc brake prop valve? Are they the same power to manual brake? Thanks,Todd
i am not sure if they are the same. i have it off the car, it is for power disc brakes. 38.00 shipped to you
If you feel like selling the molding clips for the front and back windows, let me know?
no good on sail panels. ill check the other car in a few days
Let me do some checking on my end I am interested if it will work,heck i will post a question about it!
Ok couple people say they're the same so how do I pay pm me and I will take care of it.
Would you happen to have the drivers side Clip under the sill plate that holds the seat belt case up off the floor.. Its just a little piece of metal, plastic coated on the end?? If so how much??
