Who makes the harness bulkhead connectors?
pauls340
17 miles N of Detroit
Replacing my main under dash harness I broke one of the bulkhead connectors that connects to the backside of the bulkhead in the engine well. Any idea if these are available? Thanks
The year of your car matters (always tell us). I know the connectors in my 65 Dart are different than in a 74 Dart (I tried). Also, early models had 2 connectors. Mopar switched to 3 connectors when the wiper motor moved to the engine bay. The bulkhead side varied even more I think.
Evans wiring has them: http://www.evanswiring.com/catalog.htm
If I recall, they're about $15 per connector and include the foam gasket in down in the bottom.
From what I saw on the Evans' webpage link, those connectors are $70...I wonder if that is all inclusive of all 3 connectors, plus the firewall plug-in piece. Hopefully, that $70 wasn't just for the items you showed. If so, I think that I''l be pulling out the elec cleaner, wirebrush/sandpaper/emory board & epoxy for my fixes.
