Dusterdude72
IN MOPAR MUSCLE MAGAZINE
hey guys, just now getting around to inspecting/servicing my 8 3/4 489center SBP rear end (had a leak at the center section and I also had a growling noise while driving).....anyhow, leak was due to a bad seal and the growling appears to be from a missing axle adjustment lock down tab/previous owner never adjusting the axles and there being dang near a 1/4" of end play on them and the axle hub riding on the adjustment plate...etc...etc....
anyhow.....what I am wanting some more clarified info on is.....so part number decoding and thoughts and opinions on my setup.
a little background.......the previous owner had the rear end of the duster gone through and upgraded some time prior to my buying the car in 09. But he never told me what all exactly had been done and what parts were used etc...etc... (which is my reason for tracking down all this info in this thread). I do know that little to no miles had been put on the car after the work had been done to it by the previous owner. and i have put no more that 15 miles on the car since I have owned it as i have been restoring it the last 3 years....so everything is still basically new..
first of all.....I believe this is a clutch type sure grip ...correct?
and isnt it the most desired factory set up to use?
The part number on it is 5 31 68 A 26354x
can anyone tell me what that decodes down to? ( tried running the numbers through search engines and what not but with no luck).
also my ring and pinion is 4.56 ratio (41 tooth ring/9 tooth pinion) not sure who manufactured it, but normally you would find all the specs stamped into the side of the ring ....but the only thing I found was what looked to be a hand engraved set of digits which were 276 F . can anyone make any sense of that?.
also my axles I found part numbers 2800182 9 2 85 0
and 2800182 9 2 175 1
my leaf springs I found part numbers 1981 and 1982 on (which I believe i traced back to as being mancini racing heavy duty springs.
basically looking for clarifications on some of these numbers i have found (mostly so i know what is factory and what is aftermarker and so i know exactly what I have.....I don't like not knowing about stuff like that lol).
also if anyone cares to chime in and let me know what they think of my setup (good bad,ok,rare,trash) etc...etc...
any help and info is appreciated!
![IMAG0776.jpg](http://i60.photobucket.com/albums/h31/swapper86/IMAG0776.jpg)
![IMAG0777.jpg](http://i60.photobucket.com/albums/h31/swapper86/IMAG0777.jpg)
