How to put water/crank pully and harmonic balancer on
1973dusterkid
Watch This
Buford Georgia
Ok so how do I put the water/crank pullys on and how do I put the harmonic balancer on.I cant get my crank shaft pully and my water pump pully to line up.Am I missing a spacer or something or do I need to put the harmonic balancer on with a a feller gauge behine it.
What if I use a 318 top and a 318 bottom on a 360
my water pumps are different from each other , thats why i have to use different pulleys. if your pumps are different , you will be in the same boat. are you not able to hold them on the engine and see if they will work? both my crank pulleys are the same exact 2 groove. its only the top pulley that is different.
Trial and error is how you will get the answer for your car.
