screeminDemon
just about completed the swap on my old slant 6 demon, which is now a 360 Demon with 8 3/4 rear... but the brake drum issue is stumping me. I've ordered from Summit... drums were correct 10" but too deep (3 3/4"). Same thing with drums from autozone. The drum hits the rear end housing backing plate before all the studs are fully thru the holes.
Note: the original drums on this 8 3/4 housing were small bolt pattern, and they were pretty much shot anyways.
Any suggestions? Do I need goto a junkyard? Do I need to get different housing backing plates? Thanks for all your help!
