hobart63
Active Member
I have a leak around the pinion gear where drive shaft connects. I wanted to replace seal but, don't know how to replace it.
It all depends what case # it is.489,741,742.
Which is???I have 71 Dodge Dart Swinger. It has original rear end.
I don't know what size rear end is.
There it is Thank you 73AbodEE, I saved it again
After looking at the pictures 73AbodEE put up it looks like the 8 3/4" rear end. I went to oreilly's and they told there was 2 different gaskets so I went home and looked and the back does not come apart. You have 2 drop the front of rear end with pinion gear and all.
Your welcome. A factory service manual is a great investment for someone wanting to learn and do their own work. Their not real cheap at $50-75 but their miles ahead of a Haynes or Chilton's manual. Worth every penny IMO. You might look around and see if you can find one. I got mine off of E-bay for $60
